Hi,
I have a 2001 Mercury 25ML 25 HP tiller engine. As I shift into reverse it seems to rev higher than it should, and the gears grind a little because of the high RPMs (hence I want to get this right before messing with it too much and destroying the reverse gears). A bolt holding the throttle shift linkage gear (the thing around which the cables go) was loose and I think the cables might have come out of adjustment (or something). I replaced the bolt and now It idles in N fine, and in forward, it is fine, but reverse seems to rev high (very high!). I don't know exactly how to troubleshoot it, and I don't want to mess with it too much while the engine is on... to preserve the gears.
Suggestions?
Suggestions?
