Trying to help a friend get his motor running. It floods spitting fuel out the front of the carb. I have rebuilt the carb, including new needle and float. When the carb is apart and upside down the needle shuts off everytime, when it's on the motor it won't shut off. I have adjusted the float even to extremes and it does not shut off. I can't for the life of me figure out what's going on. Does not seem to be binding on the pivot pin, I polished the seat(non replaceable) and the needle seems to work and shut off smoothly with the bowl off. I'm about ready to order another used carb as its driving me crazy. Can the vaccum pump create to much pressure and blow off the needle? The primer bulb won't get hard and will flood it as well. I'm sure it has to be the float and needle but cannot for the life of me figure out why it's not shutting off. I appreciate any help, I'm a motorcycle mechanic and outboards are new to me. Would rather not throw parts at something that should be so simple.
