JSGOLD
- Sep 22, 2009
- 609
I changed out water pump the other day as the old one was suspect and everything seemed to go to plan. However though the pump is fine there is no forward gear at all. Reverse kicks in but nothing on forward gear. I had a time getting the rod up into the motor and the clip was a pain (mine has a starter and wiring so it is crowded) but everything lined up OK. Maybe rod is backwards ( I noticed it could rotate when the lu was off) or maybe something I did wrong?
