Jean Narrache
- Jul 30, 2016
- 3
Hello everyone !
I just rebuilt this outboard and did a break in period.
Yesterday, i was cruising on my way to a fishing spot, RPM was about 4600 - 4800.
Suddenly the engine had a loss of power, like when you run empty... so i believed that was the reason. Surprisingly i still had way enough gaz to avoid such situation. So i looked at oil gauge in the front cowling and showed little to no more oil. So i added one quart believing that was the reason... Nope ! No changes. Engine start up right on demand but runs rough now, put in gear, gave gaz and something was going wrong, not much power, no way to go over 3000 RPM at WOT... !!!
While doing the break in period, not thrusting the injection pump, i pre-mixed the gaz and the pump did it's job too. So oil mixture is pretty high ! So i believed that the plugs were fouled and then scrapped, so i changed the plugs, but nothing went better with new plugs.
I noticed that voltage was at 15.8 - 16.1 volts... Way too high !!!!!
Could this have damaged someting ?
Thanks,
Mike
Thanks,
Mike
