charlie128
- Aug 26, 2012
- 5
I picked up a mercury 40ELPTO with the carbs off the guy that I bought it from was going to clean them so I have now got them cleaned and one bowl has a drain and the other does not I'm thinking the drain goes on the top carb and the hose that hooks to the drain goes back to the solenoid? I don't know for sure since I was not the one that disassembled everything I'm hoping someone on here can help thanks Charlie
on a side note the guy said it would only run if he poured gas in the carb and he had gas coming through the filter and to the carbs but wouldn't run unless he poured gas in the carb and cut right back off when it burnt the poured gas
