Starts easy on second pull, runs well but quits in about 5 minutes, like it's a fuel problem, but then starts right back up again on first pull and runs well again for a few more minutes, then quits again. the water out the pee hole is not a full stream but seems to be spayed kinda, like the passage is partially blocked. I've replaced the points and condenser. the coil wires were corroded through on the positive and I soldered in a splice. It was acting the same way before I did these repairs. I checked the fuel bowl and float, didn't appear to be any problem there.
