mercurymang
Master Chief Petty Officer
- Jul 14, 2012
- 850
I have a '75 650 3 cyl with a distributor. I took it out last night and I could hardly keep it running at idle. I tried to do a link n sync on it today but I have a question. I am able to the throttle pick up point which I have at around 4 degrees as well as the cutoff point which i have around 23 degrees. The thing I'm not sure about is the idle. When the mercontrol is in neutral, my spark is around 10 degrees After TDC. When I get underway, I don't hit my pick up point until the throttle is past 45 degrees or so. I feel like the throttle has to gar way to far before it's opening the carb up and hitting the pickup point.
Can someone help me fill in some gaps on this?
