History, had no spark on .1 cdm. Had spark on 2 and 3. Disconnected 1 to see if 2 stopped and it didn't. Changed cdm 1 with cdm 2 and still no spark on cdm1. Thought bad trigger. WRONG! New trigger and stator(mercury recommends replacing both). New rev limiter. no effect. Checked all grounds, all connections, compression is great, checked continuity of all grounds to block, checked all wires from cdm connecters to trigger for continuity.Found a broken ground from all cdm connecters to block. Fixed no effect! Suggestions Please!
