No Title
I decided to work on it this week and found a few differences. My original aluminium top had an actual seal for the main shaft, the plastic doesn't have a seal of any kind for the main shaft. How does it keep the water from leaking out or is that okay? I think the book actually calls it a grease seal. How does the water tube connect to the pump body or does it simply slip inside and it isn't a water tight seal? The body has the space along side of it so i don;t see how it can seal. My new plastic upper pump body has some parts taped to the inside of where the water tube would be, but from the bottom. What are they for? In the picture you can see a thick ring next to the impeller, What is the thick ring for?
When removing the base I did remove the studs, just wouldn't come loose otherwise.
