I'm hoping someone can verify or correct my troubleshooting logic on the problem I'm experiencing. I searched the forums and couldn't find anything similar
Boat starts and runs fine, shut it off and I hear the starter spinning. Just spinning fairly quietly, not turning over the motor. Starter is one year old, I had the boat out 3 times since it was replaced. Hopefully the starter solenoid was replaced as well but I can't tell by looking.
When I turn off the battery, the starter stops spinning. Turn the battery back on and it engages the bendix drive and turns the motor over. Turn it off and back on, and whatever was stuck has unstuck itself, and the engine starts fine using the key except the starter is spinning quietly again when I shut it off.
I'm thinking the problem is the slave solenoid since the bendix drive isn't constantly engaged which I assume would be the case if the starter solenoid was stuck. Maybe centrifugal force engages the bendix gear when I turn on the battery, and the quick on/off battery switching is unsticking the slave solenoid.
The boat is a Seadoo Speedster with the Mercury M2 jet drive. I didn't post in the PWC forum since jetski shops generally won't touch these but will point you to an outboard mechanic.
Any advice would be greatly appreciated.
Thanks,
Matt
Thanks,
Matt
