Hey guys. I have a 2000 Mercury 90 ELPTO that I've been refreshing and when I recently went to set the mixture screws, I had a bit of trouble that I would greatly appreciate some input on.
The carbs are freshly rebuilt and I took the boat down to the ramp, submerged foot, started it up and let it warm up for 10 minutes or so. I then put it in forward and started attempting my adjustments. I had the screws on all three carbs set to 1-1/4 turn out from lightly seated at the onset. Heres my problem. On the top two carbs, I could turn the screws all the way in with no change in how the motor idled, the bottom carb would cause expected changes to idle quality as screw was adjusted. This just really seems weird to me that I can close the screws all the way like that yet it still run. All the idle mixture screws were replaced during rebuild.
Has anybody experienced something similar to this or have some insight on what might be the deal here?
Also, as a general question, when adjusting the carbs, do you adjust one carb down to where the engine sputters then 1/4 turn back out before moving to the next carb, or do you make small adjustments to each until you find that spot and then adjust them all together?
I probably have the screws turned out 2 full turns at this point, hoping that since the factory manual stated to use 1.25 turns out as a starting point that it would be safely rich enough to take out for a little while. It idled okay but there was a hesitation at about 2000rpm before it kicked over to the high speed jets, which sounds like a lean condition? It ran at WOT beautifully.
Any information that anybody can offer will be really appreciated. Thanks!
