motor boater
- Dec 24, 2012
- 219
By no means do i know what im doing but i have a manual for my motor and am trying to learn as i go, but i dont see anything about this in the manual.. So here it is.
As i am rebuilding my motor (swaping out old parts with new, gaskets, plugs, wires etc) i removed the ignition coils, and what appears to be a ground wire that comes out from the inside of it just happened to fray and break off. My question is, can i replace this cable somehow? Or should i just buy two new coils? The motor ran fine before i took it apart, and i havent put it back together yet cause i see no point in doing so if this is now a broken part.
Also, as im looking online for the part, i dont see this cable im speaking of in the pictures of the new part.. Am i just missing it or l should it be there once i get the part even though i dont see it in the pic.
Attached are a few pics, one of a coil with the cable i speak of attached (not a pic of my coil) another pic of the coil i see from the marine site i would be puchasing the new coils from, and the last one is a pic of my actual coil with the broken off cable.
I appreciate any help i can get. Thanks in advance
