92 Mercury 115 2+2 4 cyl. Compression good, carbs recently cleaned, filters changed. Engine runs good at idle, Runs good initially, but starts sputtering randomly under a load. Go back to neutral, then will run good again for a little bit then start acting up. Basically will take off fine pulling plenty of RPMs then will not rev over 3500 or 3000. Problem gets worse the longer it runs, but seems to be random? I was thinking stator or switchbox from the research I have gathered, anyone else had any of these problems?
