midgetme23
- May 15, 2013
- 34
I have a mercury 500 that was running great. Was cleaning the old boat up so decide to clean motor to big mistake run better dirty. Well got to river motor started and run good for bout 30 second v while warming up. Since then I have got it to hit a lick or 2 but will not run drain bowls on carb just in case water got in it. Still nothing. Check the spark with a gauge and I'm only getting about 1/8 spark that is blue some times lite color other times can get a good 7/16 spark coil ohmed out round 50 ohms but it did ohm out any ideals checked coil wire going to dist cleaned all connections when it does hit I got throttle all the way forward when I back it off it dies
