I need some help figuring out an issue with my outboard.
when the engine is in neutral it revs up fine, seems to get top rpm (I don't have a tac), but when in gear the rpms are maybe half what they should be. When the boat planes (I have to move forward in the boat to get it to plane) the RPMs are higher, but still not 6500.
I have:
Changed the plugs
fuel filter (this helped with idling)
switched to the spare prop
run a full can of seafoam
drained the gas
topped up the engine oil
The problem started up a week ago, I was sure it was the spark plugs, but nope.
Any suggestions?
Here is a video of the motor full out: https://www.youtube.com/watch?v=Arnav_fKc5I
Thanks in advance
I have:
Changed the plugs
drained the gas
Any suggestions?
Thanks in advance
