Need some help from the boat scientists,gotta 1989 Mercury 50hp 3 cyl that I just had a new impeller put in but before I put the muffs on it and everything worked very well UNTILL I got it on the lake will unloading and driving approx 1/2 mile 1/4 throttle the tell tale stopped peeing and overheat buzzer went off so I shut it off and got to dock well now when you start motor tell tale pees fine for about 3 minutes then stops completely and the water starts coming out exhaust port above cavitation plate start above prop and will run idling forever with out over heating so I've tryed blowing air down and up to make sure there's no blockage,and wondering what could be up and if there's a thermostat on this motor
