When I cold start the motor I typically have the warm up lever set a little fast than normal idle. Then once the motor start I will rev the engine with the warm up lever. When I push the warm up lever all the way back down the motor will smoke a bit have a quick stutter then it idles fine. Once the motor is running a few minutes I can rev and lower RPM back to idle with no issue.
Is this normal or is there something I should investigate?
Also sometimes - but this is not consistent behavior, I'll run the motor out of the lake then we will sit and drift or troll for a few hours. When I go to start the motor again, sometimes it starts right up, other times it doesn't want to start at all unless the warmup lever is in max position. Once it starts there is plenty of smoke. Any idea what that means?
edit: I should add that I never have to do this from a totally cold start / first start of the day. Only after it has been running on the lake
And one last question...
I recently installed a new gas line. I have a 22 gallon tank below the deck. I bought a new Merc lined cut off one end as I have a fitting on the back of the boat where it connects to the gas tank. The hose I bought was 8 foot. I really only need it to be a few feet. Should the gas line be as short as possible or does it not really matter?
Thanks for any thoughts or suggestions!
