1984 Mercury inline 6 cylinder 90hp motor "Tower of Power" ( is it worth fixing)
I am looking to buying my first boat (its used) the boat has this motor on it, the owner tells me the following, " The motor runs well, however something broke and the motor runs, but it is not turning the drive-shaft to the outdrive. I pulled the lower unit and Splines look to be in good shape, so possibly splines on the crankshaft are bad?" does anyone have any ideas as what could be wrong? is it the crankshaft? and is this worth fixing? He told me he has done the following repairs in the past few years " the Compression was very good 140 PSI on all cylinders. New starter, CDI switch boxes, carbs rebuild and re-jetted for ethanol containing fuel, also Just put a brand new 4 blade solas prop on the motor. any help would be greatly appreciated.
thanks in advance
Jim
thanks in advance
Jim
