Mercury 60hp 4 stroke stalling between 1000 and 2000
Status
Not open for further replies.
Edsouto
I read several posts about the same problem
Did someone find the answer?
It start quickly and work well. Then it begin to be a little erratic at idle, but still ok.
It run very well above 2000 rpms, but if you stay between 1000 and 2000 for a while it begin to loose power and stall.
I changed the IAC valve but the problem persist. Could it be the MAP or TPS. Do anyone have any idea??
nuboater
Hoping for an answer to this one as I have the same problem.
flylice13
I'm here to kick a dead horse. I've got a 2016 merc 60 4 stroke outboard and mine's doing the exact same thing. Does anybody have any solutions?
I've replaced the low pressure fuel pump and the IAC valve. I now have a smooth running motor at idle but will stall out between 1000rpm and 2000rpm.
MOD EDIT: Please review the forum rule about posting to old threads.
Status
