Daniel1947
- Sep 22, 2010
- 267
I have a 1989 Mercury 150HP V6, 2 years ago it was removed from boat in order to make major repairs to rotten wood/transom etc. Prior to putting the engine on stand, I drain carbs, and fogged cylinders. I have recently finished all repairs to boat and reinstalled engine. I have always been concerned as to the oil system operating properly, so to be safe this time I have used gasoline that was premixed 50:1. and I filled both oil tanks. Just to see what was happening, I replaced the clear hose from oil reservoir to oil pump and the hose from pump to fuel line tee. When I start the engine, the warning alarm goes off, so I am assuming the oil pump is operating properly. The clear hose from reservoir to pump filled with oil, however, the clear hose from pump to tee isn't completely filled with oil, it looks as if the pump only pumps a small amount of oil as the engine is running. I am not concerned about running the engine since I am using premixed fuel. I figured that 50:1 would mean the pump would pump one drop for every 50 drops of fuel....1 ounce for every 50 ounces...etc. Maybe be over simplifying that statement, but I think the idea is clear. Question: Is the oil system operating within specs or should I consider a new oil pump? Thanks to all on this forum...invaluable information always.
Dan
Dan
