ready4itall
- May 4, 2015
- 49
My merc 9.8hp just won't give me a break.
Changed impeller, flushed water down tell tale, shot compressed air down tell tale, hosed water up water tube, air compressed air up water tube.
Peeing droplets...so...
Took off power head, found water tube deformed, changed of water tube, reassemble.
Start up and its peeing a stream (note earlier was droplets) but its not steady!!! Could it just be that the pump is just sucking up air from prop exhaust??? (Testing inside garbage can FYI)
