Okstater2008
- May 1, 2016
- 3
I have a 2005 90hp 2 stroke Mercury, and after running wide open for 5-10 mins the motor will lose RPMs and start surging like it's not getting gas or getting it in surges too. But if I back it down to 1/2 throttle it runs great and will do all day.
History on boat and motor. The boat came with 60 hp big foot Mercury and the dealer switched it out for the 90 Hp to give it more power. However I have been having this motor issue since I have got the boat home. So far I have switched out all the external fuel lines, new gas cap with vent, new primer bulb, new fuel filter, sea foam to the gas, checked the intake hose and replaced the fuel pump. And nothing has helped so far any other suggestions?
PS it only does this when in the water off the trailer. At home with the muffs or on the trailer backed into the water it runs great with all the top end you want. But when I got to unload it and go across the lake it's a total different story. Thanks.
