After the first time out with brand new gear oil in the lower unit, I noticed some oil leaking out of the lower of the two propeller housing bolts (there is one above the propeller on the housing, and one below, where it is leaking). Concerned that I might have a bad lower unit seal or something, I opened up the gear oil drain plug and a little bit of water and some milky gear oil came out. I pumped a little extra gear oil in thinking if I had a big leak it would be low and it hardly took any before spewing out of the overflow bolt hole.
Should I be concerned here? Clearly not much of the gear oil leaked out since it hardly took any additional and it was just a little bit of water. Is it normal to have leakage out of the lower propeller housing bolt? Could this just be unburnt oil in the fuel from idling? I will note that I always disconnect my fuel line after each time on the water and rev the engine up to burn off any fuel left in the engine.
Any help would be greatly appreciated, thanks!
