scalebuilder
- Jul 12, 2011
- 23
I bet this has already been answered but I can't find it. I changed my prop shaft seals a few days ago and while I was at it, I replaced my impeller on the water pump. Got it all back together and WHAM...I have forward, I have neutral and I can even put it in reverse. However, the prop won't rachet in reverse like it did before I took it apart. I've done the water pump change three times and this is the first time I've ever had an issue. The only think I can think of is that the prop shaft moved rearward a bit when I pulled the carrier out to change the seals and something is wonky inside. What have I done and how do I undo it? I've put it on with the unit and shifter in neutral, I've put it on with the unit and shifter in fwd and even in reverse. Sometimes it's stuck in just forward but right now I have it back on with the fwd, neutral, locking both directions reverse issue. Help! Thanks.
