Hey guys I have a 2001 200hp mercury it has mechanical oil pump which mixes oil in the vst motor is efi original motor was carb got a onboard 100 gal tank has a fairly new primer bulb my issue is it will start then shut off several times then it will start and run fine I cut it off and try to start it does the same thing all over sometimes it will start Rev up jus abit then cut out I'm pretty sure it's a fuel issue just don't know where to start has a mechanical fuel pump which I guess supplies the vst fuel pump which has good pressure but the primer bulb never really tightens up soft about half way squeezed orbuntil u feel a center piece in the bulb any suggestions
