Hi guys new here got a couple of things I just installed a 200 merc on my fishing boat it's efi I bought quicksilver controls so it would be simple to hook up to harness but positive wire for fuel pump on motor wasn't there so I found a power source activated by ignition my question on this should the fuel pump always run when ignition is on but not running there is no fuel return lines coming out the motor and second ? The lower end was recently rebuilt new seals and water pump I installed the fresh lower unit and I'm getting no water out the tell tale getting alil air pressure and smoke but no water at first it dribbled alil I made sure it wasn't clogged then I took the line off the head still no water but warm water is pumping out alil pee hole on the the stbd side just above the cavatation plate any advice for a diy'er
