chadweiser
- Jan 3, 2012
- 24
Since i first got this boat about 5 years ago. If i let it sit longer then a week to two weeks it is hell to crank. Once running it will fire right up if i crank it every 3 days or so. After sitting there will be a trail of oil going down the side of the engine all the way to the foot. it is from gas leaking after sitting. I changed the fuel lines and fuel pump. I cant see where the gas coming from. The engine is starving for gas after sitting because if i spray 2 stroke in the carbs it will fire up and run until it burns that gas.
