TrenchFisherman
- Apr 7, 2002
- 213
I have a 2003 90hp 2 stroke engine that has worn out splines on the swivel bracket and you can rock the engine back and forth quite a bit. I want to start ripping it apart to get the bracket out but I was wondering if there was a certain step by step process I should be following? I know I have to pull the power head but its there any secret knowledge I should be knowing? Any parts other than the obvious I should be looking at for wear? Thanks in advance!
