waytooruff
- Nov 5, 2014
- 7
Hi all. I think I have a very simple Noob question for a lot of you knowledgeable boaties.
I have owned the above motor since new and have always noticed the small stream of water that comes out the outlet in all operating conditions.
Last week whilst fishing, the stream stopped, I turned off the motor and pulled the hose off the fitting to check for a blockage. Hose was clear, but the tiny outlet hole was blocked.
While I had the hose off, I started the motor again to find a great flow of water from the hose. So all good with the impeller and waterpump.
Is there any issue with running the motor with water just coming out of the hose, or must it go through the tiny pee hole opening . Can I just drill a bigger hole to improve the flow or does there have to be some back pressure by going through the smaller opening.
Thanks heaps.
Kev.
Thanks heaps.
Kev.
