Scubasteve1
- Dec 18, 2015
- 1
Guys , I am getting really frustrated
My 40 3 cyl merc 2 stroke is driving me nuts
It has
rebuilt carbs, new float needles etc, checked for specs and clearances
new fuel pump
#1 has a new coil and spark plug wire
3 new spark plugs
new fuel filter
new fuel lines
new fuel tank and bulb ...pressure checked to see if any air leaks
Stator checked for high and low issues..none noted
I have new fuel and run seafoam
Here is the issue
It runs great for the first 5 min, then goes to limp mode,
total power reduction..5300rpm to 2500 ish...idles rough in limp mode
Last year it did this before all of the above repairs...
I am a pretty good mech but am out of ideas
Please point me in a good direction
Thanks
steve
PSI added a new water pump and fuel lines on the engine...
Checked the vent, and its clear
It has
new fuel pump
3 new spark plugs
new fuel filter
new fuel lines
Here is the issue
Thanks
steve
