Slacker411
- Apr 12, 2013
- 118
Ok so I have been having problems with lack of power at WOT and intermittent bog and surge. It is a 1978 Mercury V-1500 V6 150hp 2 stroke outboard. Cylinders 1 and 4 seem to have no effect when removing spark plug wires during cylinder drop test. Also using a multimeter RPM gauge cylinders 1 and 4 register about 135 and its relatively steady on multimeter. With the other cylinders 2,3,5,6 the rpms are hardly readable but show to be around 1200-1900 but the numbers jump around so fast its very hard to read. These other cylinders produce a noticeable effect when removing their plug wires. Using a spark gap tester all plug wires put out what seems like good steady spark to the naked eye.
What I have done so far:
Replaced Fuel tank, Primer Bulb and all fuel lines, thoroughly cleaned carbs and new gaskets, replaced fuel pump diaphragm and new gaskets, new spark plugs, swapped coil packs on affected cylinders, cleaned all electrical connections and points, Checked the resistance of all plug wires at 20k ohms and all checked out around 0.99 except for one that had 0.63 ohms. Positive and negative leads on all coil packs reads open circuit with 0.00 resistance using both engine block as a ground and the negative and positive posts on the coil packs respectively.
I just took the boat to a mechanic and I don't really think he did any real work or enough troubleshooting. He was telling me he couldn't even get the boat started unless he sprayed fuel directly down the carb and then it died. When I got home the boat started up easily so I am not really sure he tried to hard. On cold starts I have to use carb cleaner spray or starting fluid to get it to fire up (like immediately). Any subsequent starts after it has run for a minute or two it starts immediately with 1 turn of the key. The mechanic told me the motor is probably just worn out and thinks its crankshaft seals that have gone bad producing lack of fuel suction. This would not explain the electrical issues however.
