imported_dave j
- Jul 4, 2006
- 29
Hello, I have changed out impeller many times on this motor but never experienced this before. after install of new water pump housing and impeller I did as usual. Put motor position in forward, put lower shift shaft all the way clockwise, and put reverse lock cam in correct position. When I start motor and Mercontrol in NEUTRAL, prop spins. When placed in FORWARD, prop spins same direction. When put in REVERSE, prop still spins in same direction. Any help would be great. Thank You Dave
