Can anyone help me with the details of removing a lower unit from the subject line motor. reason for needing to do this is I am observing oil coming out from a hole above the prop and I was told that there is a seal in the lower unit that could be bad. I am believing this to be true because when changing my lower unit oil not very much came out. Also, what seal would need to be replaced
Thank you
Bill
Thank you
Bill
