Was given a non-running old 3.9 (no ID found on it). It is not frozen but cannot pull the starter rope. Even with plug removed, it can be turned over by hand twisting the flywheel but is very stiff. Can't pull at all in neutral, forward or reverse most of the time. At other times, I will pull but pulls very slowly and like it has tremendous compression. Thoughts?
