got a 8hp mariner, its a Yamaha built one, model 6G1-L-308585. pulled the plugs out and all around the threads is this milkly fluid. both cylinders test around 130 psi compression. how does water get in? motor seems to run pretty good.
I'm in MN. Freshwater only. 50:1 oil mix. This is a Yamaha built Mariner. I also have a Yamaha 8hp that looks identical to this one. I just got it. So I don't know its history. Best I can see, it looks clean inside both cylinders.
