bashunov456
- Sep 29, 2015
- 7
Hey guys, I am looking for help with my Mercury Outboard. I picked up a 15.5 footer boat with this outboard on it. Took her out on the water the day I bought it and everything was working flawlessly until we shut off the engine near a dock. When we tried to start it up again it was not having it, just cranked and cranked but did not run(my initial guess is that it was flooded). We tried it again and again with breaks but couldn't get it to start running and walked back to the cars. We drove to the boat about 30 min later and it fired right up and we drove it back to the launch to pick it up. At that time is when I noticed that almost full throttle was just barely above crawl speed. I did not mess with it much at the time since we only needed it to go slow since it was dark and I was not risking anything. When I got it back home I ran it with muffs and notices nothing coming out of the pisser tube so I pulled the lower unit and replaced impeller/water pump gaskets and put it back up(the impeller was totally shot- the boat was sitting for over a year before I bought it). At first I accidentally had the gearbox in neutral but the boat in reverse so I pulled it back down and lined them both up to neutral and put back and hit the water.
When I put her in reverse the whole engine was moving up and down and going crazy so I had to give it barely any throttle in reverse. The boat ran and started good every time we tried but for whatever reason full throttle in forward is just above crawl speed (guessing about 10mph) and will not go any faster. Also, even while hot I would have to use the idle assist to get not to stall when putting in forward than drop the idle assist once its moving. What could be wrong? I am pretty sure I lined the shift splines up correctly since the prop free spins in neutral so I am guessing the problem is not related to me pulling the lower unit but maybe something to do with what happened that day. Could something of over-heated while we were trying to crank it over on the dock the 1st day? I checked the throttle cables and they seem to be moving correctly. I did not test spark yet but I pulled the plugs and the bottom 2 (3 total) looks to be a little fouled since they have a little black oil on the ends of them.
Any feedback would be appreciated!
thanks
thanks
