Troubleshooting an old boat, and it seems to me I am getting fuel and spark. The boat has sat for the last five years. It turns and turns, but I don't even get s shred of life out of two days of working on it. I have tried starting fluid through the carbs and in each cylinder. I also have tried different choke and throttlenpositions while starting. I primed the bulb until it was not squishy, and opened the fill on the tank to prevent. A vacuum or siphon.
I have cleaned the carbs, replaced the plugs, using new fuel at fifty to one, and am running out of ideas. I cannot verify compression, but seem to be getting a good suck and push on each cylinder through the cycle. When turning the motor over without plugs, i see a vapor in the sunlight so I am ruling ou getting fuel to the cylinders. I also have spark.
I am thinking there is a kill switch somewhere I cannot find. I have removed the Mercury tilt switch, but no change.
I'm about to drop it off at a repair shop, any ideas would be appreciated.
