Mercurylips
- Sep 23, 2015
- 189
Purchased an older Sylvan with a 50 hp Mercury and when it went out on a test run it ran smooth but would do no more than 5 mph. So far I have cleaned and adjusted the carbs and replaced the bulb and hose, and the spark plugs. Found out the throttle linkage was a mess so had that redone.Now the motor runs strong after it warms up but suffers a top cylinder power loss at times. It starts great when warm but not cold. I am thinking plug wire or the top one of four coils could be faulty. I don't want to keep throwing money at it but I think it is a keeper and would like to know what else it could be. It runs great at top end and after a few minutes you get a drop in power but no sputter. Like someone just took a plug wire off. It will then go back to full power for a while and then a repeat. Easy to feel and hear. Thanks
