Ricky_rich
- Mar 4, 2014
- 114
What will happen if I run this engine with a small hole in the baffle exhaust plate? Is this really serious and need to be fixed right away?
It will allow water into a cylinder or two, causing them to not spark and not make power. If you know there is a hole in the baffle, you obviously have it apart. It is time to replace the baffle plate and gaskets.
Usually when you have one hole, there is pitting all over the baffle. If you have pitting, it will develop another hole in short order, so not worth it to weld it.
