Serial # g646570. Leaking oil from around the prop. I understand it has an o ring seal and an inner and outer oil seal. However, i can only find the o ring seal? Do i have to remove the prop shaft itself to find the others? Or is it leaking from the O ring. Any help is much appreciated.
