I am having a problem with my 2006 90 Mercury 4 stroke efi. It starts, idols and runs great but at full throttle it keeps wanting to shut down every now and then. feels like it's out of gas but if i drop to half throttle it runs fine.I can troll all day with no problems and it doesn't happen every time i use it. I have changed the plugs, fuel filter, oil, checked the pick up tube screen in the gas tank, added water remover and fuel injector cleaner to the tank and sprayed a can of fuel injector cleaner into the throttle body while running. i'm still having the same problem at full throttle, every now and then it feels like the fuel is shut off. but runs normal when i back it to half throttle. Could this be a sensor issue? anyone had the same problem with this engine?
