I just replaced a switchbox and was on the water to troubleshoot what I thought was electrical issues (intermediate spark) when I noticed the inline, clear, fuel filter was almost empty. I would assume that the filter is an extension of the fuel line and should remain full. I also noticed that it looks like there are bubbles in the fuel coming to the filter. I recently replaced the lines and filter because my old lines would leak fuel and these new lines seem airtight. I do not know where air would be coming from unless it is from my tank being almost empty.
Symptoms - launch boat, idle out, go WOT and run for about a minute fine and then it fell flat on its face to about 25% power. From there it will only run 25% and sputters and spits the whole time doing it. I also noticed that the bulb was soft. If I pumped the bulb until it was firm I could go WOT for awhile until it would start sputtering again. The whole time my fuel filter level was fluctuating and looked like it was starving and lots of bubbles. I plan to rebuild fuel pump tomorrow and maybe try to replace fuel lines although I do not know where the air would be coming from.
I think this whole issue started when I sucked up some water from the gas tank. I have not pulled the carbs yet but hope I don't have to. The carbs should not have an effect on the amount of fuel getting to them from the filter would they? Should the filter be full at all times? or is the fluctuation and air normal?
Thanks,
Dan
Thanks,
Dan
