Mariner 30HP long shaft: year of manufacture and shallow drive questions?
Yukoner Ted
Identification plate stamped 689 L 553684
Is this motor supposed to have a shallow drive function?
Thanks,
Ted
minuteman62-64
I'm having trouble reading the serial no. info, but looks to be somewhere in 1992-1994 range. I'm sure one of the guys that really understands the tables can chime in with the exact year.
Not sure what a shallow drive function is, so, can't help you there.
Yukoner Ted
Shallow drive is a linkage system that allows the motor to be tipped up and locked about 25 degrees or so above the normal operating position. I have had it on several 15 and 30 hp Johnson, a 20 Tohatsu, and also seen it on numbers of other outboards.
Thanks,
Ted
flyingscott
Late 70s to mid 80s motor built by Yamaha do not believe they have shallowater drive on them. They are hard to date i had an 8 hp mariner built yamaha even mercury could not tell me when it was built. There are people here who know.
Yukoner Ted
Appreciate your reply, flyingscott. The odd thing is I have a 5 hp Mariner on the same boat that was bought bought the same year by my friend, and it has shallow drive.
Ted
Yukoner Ted
Still trying to determine the model year if anyone can figure the serial number out. Want to order a couple of props while they are on sale here.
Identification plate is stamped 689 L 553684
Thanks,
Ted
Mohawkmtrs
Best I can tell from Marinshopen, it is 1994 Model 30 ELO.
Serial Range: 689-553066 - (open).
