The oil injection pump failed on my 1990 mercury 150 xr4 and now I have low compression on cylinders #1 and #6. All cylinders are 145-150 psi and cylinder 1 is at 115psi and cylinder 6 is at 125 psi. It's hard to start without a long choking time and runs a little rough. Is it most likely the rings where damaged on those two cylinder or could it be something else? Would a hone and re ring be a sufficient repair or is the powerhead done?
