mallardtone-man
- Sep 22, 2008
- 110
I just finished putting and impeller and gasket kit into my 1999 115 mercury last night. there was a step in my manual that's sad to remove the jam nut on the shift coupler then turn the shift ride coupler until the upper and lower shift rods are separated prior to removing the gear case. I was not sure what the shift coupler and tried digging in the manual but couldn't find it. I also watched a youtube video where 4 the impeller on this motor and he didn't do this step. That I decided to move forward without doing it. then at the end of the procedure it says to adjust the shift linkage but does not explain this. I just want to know if these steps were necessary Or not. I have not tested the motor yet or even tried to put it into gear for fear of damaging the linkage if I did something wrong here.
A side note When i put the Gear case back in I had a fair amount of trouble getting the cap on the gear shift splines to line up. I was able to freely turn the part of the gear shift that runs toward the prop through the gear case about three quarters of a turn in each direction before it would stop. And I'm not 100% sure what position it was in once I finally got it lined up. I want to make sure that this will not affect anything in my gearbox.
