I'm brand new to this boat(all boats really) and I've noticed if I run it at 4000+RPM that the temp gauge rises fairly quickly to 3/4. At cruising speeds it is at half and when putting around it is around a 1/4. I didn't run it too long (2 min or so) at WOT as I didn't like the temp so high. It has a new water pump. Also if the boat is trimmed all the way out (3/4 on gauge) and running it hard it is difficult to steer. (does have a whale tail) It does not however make a rooster tail which I thought it should. Any help is greatly appreciated
