Happybob52
- Aug 27, 2015
- 11
I'm having some issues with my 50 Classic cooling system. It's not peeing right. After a minute or so at high rpm, the stream stops and it just starts spraying steam(or exhaust) with very little water. I had the impeller replaced a couple of weeks ago. They did not change the housing or wear plates, saying they looked in good shape. I was told, in another forum, to replace the thermostat & pressure relief (pop it) valve. I cannot for the life of me, find these parts on the motor. I know a thermostat should be located at or near the top of the head and the valve should be near the bottom of the motor, but where? I don't have a clue. I've been searching on-line manuals, you tube and the world wide web with no solid results for this particular engine.
Can anyone help me?? Any help is greatly appreciated.
Thanks, Bob
Thanks, Bob
