purplegrape
- Aug 27, 2013
- 16
Good day everyone, I have a 2014 90hp merc, with maybe 25 hours on it.
My issues is that I was travelling through some eel grass, and the engine sort of cut out over revved and started beeping (3 beeps), the engine was not spitting water out. I stopped the engine and pulled some eel grass (seaweed) from the intake of the motor. after that it seemed to be running fine. I made it ashore after finishing my day and ran the motor wide open on the way back (starting spitting water again)
No heres my issue. When I start the boat in the yard and put muffs on it will no longer throw water. It use to fine. So this afternoon I got a bucket large enough to surroung the bottom of the motor and cover the intake holes with water. I started the engine and she will not spit water. It beeps at me 3 beeps and if continued beeps continuously. I assume the continuous beep in overheating.
Do you think Im in need of a new impeller?
thanks,
Chad.
thanks,
Chad.
