There are two ways to kill spark on that motor. The first is to wire it like the blue mercury switch under the wrap cowling, and ground out the switchbox. The second is to interrupt the supply of +12VDC on the white wire from the ign accessory post to the motor. The latter method allows all the wiring to be under the dashboard, however, you need to open up the MerControl box and wire the kill switch in series to the white wire. Also, the kill switch needs to be the "break" kind which opens when the lanyard is pulled.
Is this the mercury switch?
Why do you want such a switch for anyway?
