I have a 91 Merc 115 HP that does not appear to have any water pressure. I am testing with a muff, but also tested with the lower unit in a plastic tub filled above the water intakes. There is no sign of peeing and I just hooked up a water pressure gauge and I get zero pressure.
Background: I bought the motor 3 years ago on a pontoon boat. It seemed to run great and peed as it should while in the lake when I tested before I bought it. I replaced the impeller shortly after I purchased it just in case and it was still peeing fine when used on the lake. At the time I didn't have a pressure gauge and I never tested this motor on a muff to see what was normal pee rate. After a couple of weeks the motor developed an ignition problem and did not get used for next 2 seasons. Due to health issues the motor was not winterized and sat outside during sub zero winters.
This summer: Ignition problem is fixed and when I initially fired it up it was peeing with the muffs but not a steady stream. I thought I would replace the impeller again since it was sitting for 2 seasons. After I replaced the impeller it does not pee at all. I think I checked all of the obvious (except put the motor in a full tank of water or in the lake - neither of which is practical for me at this time).
What I've done: Replaced the impeller - Pulled the lower unit again to make sure water pump tube was installed correctly. Reinstalled the lower unit. Installed a water pressure gauge from my old merc 150 (no indication of water pressure). Removed the thermostat (left it out for now while testing). Flushed out the pee hose that goes from the block to the exterior of motor with water pressure to assure no blockage. Back-flushed from the peeing port and the thermostat with water. Still no water pressure.
I have a question that came up while I was troubleshooting that I would appreciate if anyone has any knowledge. If I hook a hose to the water tube that the water pump connects to (with the lower unit and thermostat removed ) should the water travel through the block and come out the peeing port? It doesn't.
I currently have the lower unit removed and the water pump disassembled again. From what I can tell the impeller was installed correctly. I am going back to try some more troubleshooting. If anyone has any suggestions as to how to go about troubleshooting this it would be greatly appreciated. I am concerned that there might be some frost damage since I did not winterize, but I'm not sure best way to verify.
Thanks in advance.
Thanks in advance.
